placham »
https://forums.nicoclub.com/placham-u38577.html
Tue Jun 03, 2008 4:19 pm
When I put my Tein He's and Work Rezax 17's front 8" wide. I'm running S14 FLCA with S14 spindle. I bought coil overs used. I did not adjust the ride height. Made my tires sit right against the fenders, when I pulled my car out of garage and drove maybe 20 forward and back. It rubbed insulation from my wires on driver side (just the electric wire insulation that covers entire harness, individual wires were not damage.) But you could hear it rubbing, also there was paint rubbed off the inside of inner wheel well, part were your feet are. BUT IT LOOKED SICK, with S13 front looked like a toy, front was about to my knee caps,
Since then I raised it about 1" or 1.25". I'm still having problems getting onto drive up ramps (the ones you use in garage). So any lower than that, would be a PITA to work on it, if you have to do it multiple times or frequently. If I droped the car it looks insane.
To give you an idea I had about an inch of clearance between the bracket that holds the TC rods and ground.
To make it short, yes, tucking away or relocating your wire harness would be a good idea. Unless you like to work with multiple wires
