I took the wheel off and completely dissembled the steering wheel control down to the individual plastic pieces on the left and right side.
After removing said pieces, I peeled off the the plastic layer and spray painted it with PlastiDip (~6 coats). Re-assembled in reverse.
You'll need:
- Ratchet
Tamper Torx T30
http://www.homedepot.com/p/Husky-T30-Ta ... r+t30+torx
- Torx T40
http://www.homedepot.com/p/Husky-T40-To ... /202913547
- Torque wrench 20-100 lb 3/8inch
https://www.lowes.com/pd/Kobalt-3-8-in- ... ch/3381200
- 19mm 6 point Deep Socket 3/8 inch
http://www.homedepot.com/p/Husky-3-8-in ... /202913533
- Standard Philips Head Screwdriver
Use this guide and video as a reference so you know what to expect, as they are very similar:
https://www.myg37.com/forums/d-i-y-inst ... t-diy.html
https://www.youtube.com/watch?v=899N0siOE0k&t=855s
In case you don't know how to use a torque wrench:
https://www.youtube.com/watch?v=3v3hLvuO_KU&t=206s
When you remove the airbag, set it aside facing upright (according to service manual, contrary to the above video).
Right after removing the center nut with the torque wrench and 19mm socket, be sure to take a picture of the center of the steering wheel and column, focusing on where the lines sit. They won't perfectly match up, it'll be either on the left or right side. Install it exactly like so when you re-assemble.
After you remove the steering wheel completely (Mind the cables!), follow the above g37 guide to remove the rear housing and then just look for the deep small philips screws to take the rest apart.
If you or anyone else need any additional help, feel free to dm me and we can even facetime or skype to go over what doesn't make sense
