Earl's part # 9919BFEbeans33 wrote:Does anyone know what fitting to get for the block for my top mount oil line setup. I know the block is a M12x1.00, but I dont know where to get a fitting for it to make the line. Any help is appreciated. thanks
You'll keep the 90* block fitting.dvd wrote:so the adapter would go into that 90degree thing that comes out of the block right? or does it replace it?
which is also a restrictor is it not?float_6969 wrote:You'll keep the 90* block fitting.
