Is there any significant differences between the S13 and S14 exhaust systems? And as far as the E-manage is concerned, is it fairly easy to program (in my likelihood, reprogram)?:: orion :: wrote:It will physically bolt on...but the E-manage will be tuned improperly for your ECU and MAFS.
I wonder if that eManage statement true. Anyone know of anyone who has done the necessary mods to make this kit work w/o modding the eManage unit?bruinbear714 wrote:The kit was made for S14. To mate to S13 chassis with KA24DE, you will need to do some physical modding on the pipings.OBD2/1 doesn't matter.. the emanage will hook up to the 93 KA24DE the same way it does with the 96-98
I know when I put the Greddy Kit on my 95, that (supposedly) it is only because I have an OBDII equipped 95 that the emanage works as-is. Supposedly (again) from what I understand, the emanage will work with OBDI but you have to use the e-01 to make it work. Since that wasn't the case with me, I never bothered to find out why that is, but that's what they say.wannawangan wrote:
Good luck.Jonenjukuracing wrote:This Kit is Designed for OBDII. If own a 1995 this kit will bolt on but if does not have OBDII you will need to purchase the Greddy Profec E-O1 or Support tool to reprogram the E-manage system.
more like, to hell with greddy's tuning, buy the support tool and get a better tune.golgo13b wrote:If I understand what every body is saying; To hell with the e-manage, the rest fits, just run some other stand alone.
