rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Sat Mar 12, 2005 6:29 pm
Ok, here is how I did it. I had a stock SE lip, so if you don't have that, this will be no help.
The stock SE "lip" (more like a black line under the front bumper) has a reinforcement bar that mounts on the plastic bumper. YOu will see it. It is about 3 feet long and slightly curved. You have to take that as it has threaded studs bonded/welded to it. I cut those apart (as the holes already in the bumper and lip are the same size) and use those. Kinda hard to imagint I guess unless you are in there. I knew I should have taken pics. You will figure something out, but no: it is not a bolt on! I thought it was as well. Took me like 3 hours to get the damn thing on Looks killer tho!
