Okay so over the past few months I have recieved numerous pm's about how I fit my 33's and many topics have been started over this issue also. So I finally am making one thread that will discuss what I did and any issues that were had with the tires.
Tire Size
Okay to start off what size tires am I running? I call them 33's but they are really 285/75/16's which when new is 32.9 tall and 11.5 wide but actual height varies by brand, I am running a BFG AT. When I got the tires they were a bit worn and measured a 32.8 but thats close enough to me, and the difference between new and used would not require much difference in trimming if any at all. I would imagine that a 33x12.5 would rub ALOT MORE and you would need a bigger wheel spacer/adapter to run a 12.5. As it sits now I have very little distance between the edge of the front tire and the struts. Note that I am NOT running a 33x12.5 only a 285-75-16.
Suspension Setup
I am using the AC 2in Lift available at 4x4parts.com. Now onto the issue about acutual height. I know that the tires will fit on an AC LIFT, I DO NOT know if they will fit on an OME suspension, if someone wants to measure fender height we can compare and see what the difference is. I know it has been done a few times on the ac lift but I have not heard of or seen anyone running 33's on the OME setup.
Wheels and Their Backspace
Now onto this delicate and probably most important detail of fitting 33's and being able to use them and flex without issues. Acutal wheel size does not matter, you can run a x15,x16,x17 whatever, what really matters is the backspace of the wheel. I am using the stock double tri spoke wheels which have a backspace of 4.25. I will not post up pics of the other model wheels that work, anyone that can read this post can also find out the backspace of their wheels. Any wheel that measures a 4.25 or larger ie. 4.5 and up will work. Wheels that measure a 3.75bs WILL NOT WORK. The backspace of a wheel determines how far out from where the face of the wheel is bolted to the axle sticks out. The more backspace the less it will stick out, the less backspace the more it will stick out. So in short a 4.25bs wheel will look to be inside the wheel well while a 3.75bs wheel will look to be even with the fender well. This leads to the issue of being able to flex and tuck a tire. Its common sense that when the tire sticks out farther it will be out more, and then cause issues with rubbing on the fender flare. Because the wheels backspace is 4.25 or greater the outer edge of the tire will just miss the fender flare and tuck nice and neat into the wheel well allowing the axle to articulate without issues. See picture below for tire tuck.
Tucking a Tire without rubbing
Wheel Spacers/Adapters
Now even though you have a wheel with the proper backspace (4.25 or greater) You will be able to properly fit the tires in the rear without issues, the front however is a different issue. The front suspension of a R50 is a Strut setup. The bottom of the struts have a cup around them that sticks out quite alot. Now if you attempt to put on the tires and wheels with the 4.25 bs it will NOT work. In order to fit the tires up front you will need a wheel spacer. You will need a wheel spacer that is atleast 1.5in This wheel spacer will effectively put the mount for the wheel and tire further out increasing the distance between the edge of the tire and the bottom cup of the strut. Now you may be asking yourself why would I do that because then the tire will stick out past the edge of the wheel well. You would be correct in stating that. The reality of the issue though is that the front suspension of an r5o does not flex, it does but not much at all, let alone enough to cause issues with rubbing on the fender flare. Note: I still have my front sway bars on and have not wheeled with them off, I have heard that it flexes somewhat but I dont have experience with it, so dont blame me if you take it off and it rubs
http://ruggedrocksoffroad.com/trailgear ... -3667.html
Wheel Spacer
New Stance with wheel spacers
Trimming and Rubbage
Okay here is the part that most ppl have questions about. I had to trim, but it was nothing that a dremel or shears cant handle. I had to trim the inner fender well liner and some off of the front lower part of the bumper. The VERY Bottom of the fender flare had to be trimmed and it is not noticeable unless you look up from the ground. I also had to remove the front mud guards, otherwise there would be massive rubbing. Understandable trim varies by year and trimming will vary but this is a common trim and thats what I had to do. Here are some videos I took and put on youtube about trimming and fitment of the tires. These videos show everywhere I trimmed and how much.
Trimming
http://www.youtube.com/watch?v=RitQ-IGoRfs
General Pics and Stuff- 0-60 with the tires :jig:
http://www.youtube.com/watch?v=jdtCjdmqDKo
Why you SHOULD do it
Well its a good question, with a simple answer....its AWESOME. Its crazy I gained about as much lift as my actual suspension lift gave me :lol: Performance atleast with a VQ :sly: is still good for a lifted SUV and it is not noticeable. Your gas milage will suffer a bit, but hey if you wanted good gas mileage you wouldnt be driving a lifted SUV :doh: But Id say if you want to do it go for it! I will post some pics below to entice yall to do it. I believe that I have covered just about everything, and this has taken me about 45 minutes to type out and link and put pics in......so I hope I covered everything, if you have questions please RE READ this post and then if you still have a question. Now its almost midnight and I have class at 8 Am tomorrow Night yall
