Fitted clutch, engages very sharply :(((
Vetal
Fitted my Spec Stage1 clutch. It's completely organic, not so far from stock. It engages very sharply - during about 1.5cm of pedal movement... What can be the reason? :confused: Was it fitted incorrectly, or what???? Can it be adjusted somehow? City driving is very hard... Almost stalled few times...
nab911
Car: 93 Nissan 240SX SE
More power will fix that problem :)
Notchbackca
Car: guess...
you bought a performance clutch... thats what they do
slw240sx
Car: 1990 Ca18det 240sx Hatch
you should try a 4puck they say its not streetable, it is but its difficult. lol
NeedCAforS13
Car: CA swapped S13 coupe
I have a 4 puck unsprung. I can drive it pretty well now, and Dee drives it flawlessly:) Takes awhile to adjust to it!
Sean
Vetal
I feel like I have gotten the supposed-to-be-streetable organic clutch that engages more like 4-puck. I don't think it is right.
USDM_OneVia
Car: Racing
Great..... and I just bought a 4 puck too.
Vetal, make sure they bled your clutch correctly too. Although completely unneccessary, they may have taken the line off the clutch slave cylinder to remove the transmission. My S14 is WAY stiffer than both my S13's and the fastback just got a brand new OEM clutch installed.
Joe
Vetal
They swear they didn't and it doesn't need bleeding... But could be a good idea to try to bleed it though :)
240 Trainee
How do you guys bleed the clutch? I have to now( installed SS clutch line), and I can't get it properly blead. I am doing it according to the FSM, pumping the clutch, and opening the beader valve, and that worked once, but no longer, it doesn't get any firmer. any ideas?
Vetal
What is SS clutch line?
240 Trainee
Stainless Steel line.
biosehnsucht
240 Trainee wrote:How do you guys bleed the clutch? I have to now( installed SS clutch line), and I can't get it properly blead. I am doing it according to the FSM, pumping the clutch, and opening the beader valve, and that worked once, but no longer, it doesn't get any firmer. any ideas?
If you haven't already, remove the @#(% clutch damper, that thing makes it impossible to bleed right. there's a howto of sorts at http://sr20.hybrids.jp/install....html, I did it and it helped somewhat, altho with a mostly dead clutch on my KA (starts slipping after ~30 min of normal driving, not pushing it or anything) it didn't make a huge difference, other than being able to actually bleed it.
edit: fixed link, thats what I get for letting it do auto URL
240 Trainee
I removed the box already. btw, leave a space between puntuation and you links, It took me a minute to figure out where it was. lol. I'll try to do that. This thing should be reall stiff, SS line, and a Spec Stage 3 clutch.
USDM_OneVia
Car: Racing
Make sure you don't have any leaks in the line's. If you do, you will keep getting air back in and basically starting at square one every time.
Joe
Oh yeah.... that dampner box sucks.
240 Trainee
Yea, I don't think I have any leaks. would russel speed bleaders help?
Spectre_240sx
Car: 1990 240sx SE
You really shouldn't need them. Are you trying to do this by yourself by any chance?
The correct procedure as I know it is:
Pump clutch a few times and hold it downLoosen bleeder valve and wait for fluidTighten bleeder valveRepeat until firm +1 more for safety.Oh, and never let the resovoir get low.
is that how you're going about it?
240 Trainee
I am noy holding the clutch down while bleeding, maybe that is it. amd yes, I am doing this by myself
Spectre_240sx
Car: 1990 240sx SE
I think (though I can't say for sure) that that's where your problem is.
Get a friend to come over and help you out, it will be a much simpler process :D
240 Trainee
Yea, I will. I am so excited, hopefully, when the computer coems form Kevin, It will turn out to be what I need, I can pay him for it, and DRIVE!! lol. It'll be awsome; I am looking forward to a great clutch feel! Just need to get it bleed though.
float_6969
The pedal must be depressed when you open the valve or you're not doing anything. Unless you have speed bleeders (like me, yea!) , or a vaccumm bleeder (I've never gotten them to work right) it will take two people.
240 Trainee
Well, I think I am goign to order 5 bleeders, one for each brake, and the clutch. I guess I got it to work the first time because there was no pressure, thus the pedal syaed donw the first time.
240 Trainee
what size do the Nissans use? I am guessing the 10mm x 1.0, but that is a guess.
