Rex wrote:What size tire you run will (of course) play a role in this, but with the information at hand ...
Fronts should have no problem on the inside, but you're (probably) gonna need some camber and roll the inside of the outter lip, maybe a pull. Really depends on what tire you put on that wheel.
The rears are gonna be a tight fit if not rub on the inside, are you going to change the suspension, will it be a wider shock/strut than stock? And I think you'll be pulling & rolling the rears. Unless, you simply allow them to stick out from under the car, but you won't be as low then. Again, the tire you put on the wheel is gonna play alot in your clearance equation.
Those are my opinions based on the *math* of the stock wheel/tire size and offset.
I think Falk summed it up nicely...
Those sizes you listed will fit with no problems up front.. like I said on VIP style I would suggest a spcer up front, so the front isn't sunken, while the rear is flush. On the rear roll it good, and see where you stand, you definatly won't need to pull either the front or the rear.
And just out of curiosity, how did you come to the conclusion that this size would rub the INSIDE (i'm assuming suspension parts) ?
