so i got the 240 from some nice old lady far from north jersey ricers and jersey shore guido fisters. alittle rust but nothin to worry aboot.
how she stood when i bought her. 1100 bucks. clean with a tiny bit of rust that was taken care of by frank down at pride performance. welded on a sectioned off coupe quarter panel, frame rails were reinforced and strut towers taken care of.
poopy ka out
if you see anything you like in this pic , let me know
time to find an sr... found the perfect setup from antony(auk113123445345). went down and interrupted a cool little meet in the cave. btw pa scene>jersey. comin back from anthony's place with a one-off srswapped midengine kia sedona
then i said **** it, i'm swapping my newly acquired ariston 2jzgte into the vert muahahahahah
i kid... it's for the sc300. again.... muahahahahhahaha. neway
found a silvia whole front end swap, metal unmolested fenders, trip proj, everything from two kids from pa(again thank you pa) with r32 gtr's. kool a** mofo's. shout out to andrew from levittown
rps stage 2 clutch in and ready for trans thanks to mvp motorsports
my boy brian helpin me with the swap... couldn't do it without him. thanks bud
had to cut the old pos motormounts off... stripped them ****s taking the ka out
god damn puerto ricans...
red rocket? me hope so bery much
installation of man pedal
don't worry... i cut the brake pedal down a bit
engine bay clean and motor clean... ready for it's final resting place
****kkkkk i should probably have changed the oil filter...
home sweet home
hey ant... i just want to confirm that you can work with these two sensors... they look ****ed up beyond recognition so I was thinking or ordering these two anyway... 5th gear switch and 4th gear switch respectively?
second switch closest to neutral pos switch
and the next switch after that going towards bellhousing from neutral pos switch
that's it so far... just need to pick up the rest of the pieces from antony and then the wiring of the power fc shall commence.
