droid017 »
https://forums.nicoclub.com/droid017-u187323.html
Mon Jul 11, 2011 8:44 pm
Whats up Z lovers, I bought my first Z a few days ago, and after pouring over these forums for several weeks I thought I'd get your opinions on some things. I've been salivating over the z32 since I was 16 and now I finally have one of my own, and I intend to show it some love. First things first, its a '96 slicktop TT swap, 120k on the body 47 on the motor. If I ask anything that has been answered somewhere else, I sincerely apologize, I promise I used the search bar a lot and read pretty much every article I could get my hands on. To get an idea of what I'm looking for, I want a reliable DD with some get-up-and-go for those days I want to drive it hard. Looking to put out 350-400 when done, enough to DD without killing myself, and murder all my friends with 240's heh heh.
The interior needs some loving, but thats all minor to me. My plans for her so far are to restore the interior to new, paint her, and beef up the engine enough. I'll leave my cosmetic plans out for the most part. Otherwise I'm planning on some adj. tension rods, turbo timer, bigger radiator, maybe a different intercooler, cold air intake, and a good but not outrageous sound system (I'll be driving her a lot). What else would you guys suggest for a good, quick DD? I'm pretty good with engines, so I can do most things myself or with the help of the internet.
Also what would you guys suggest for dressing up the engine bay? I've already got stainless hard pipes, planning to polish the plenum and add some other chrome parts. I just want her to look sexy.
And some technical questions.
1. How can I tell the year of the engine? I know the plenums are different for different generations among several other small things.
2. The speedometer clocks about 15 over actual speed, what should I be looking for, bad gauge, speed sensor?
3. The instrument panel is still the NA panel, should I get a TT cluster?
4. The car is currently running a tuned ECU from Z1, and I think it's tuned for boost jets because the previous owner had them sitting in the glove compartment. I would prefer to use a boost controller, how is that going to work with the currently tuned ECU vs putting the boost jets in?
5. Is there an optimal location for BOVs? The current owner has them welded to the charge pipes to the intercooler, but I've seen them on the hard pipes.
6. Current setup is a front mount, is there any advantage to the side mounts'? The 96 NA front bumper lets the front mount get a good amount of airflow, and it doesnt have the TT vents for the side mounts, should I just stick to the front mount? I want to put a 99 front on her anyways.
7. The Cruise control also doesn't work, is this because the car has been swapped to a 5 speed or just because something is wrong with the cruise control? Again, not a big deal but its nice to have.
