Hey guys referring to the original post my new bumper will be here next week and I plan on doing this so it lines up with the that I have already purchased the trans cooler and and am still awaiting gauge stuff but after seeing the suggested one I'll probably go with that. I think at some point in the coupe they came factory with a trans attached water cooler which you can buy from the stealership for 1250$, I believe the same cooler was attached to AWD Rogues with the tow package. I think the manual says to change your first cvt oil change at 60,000 and then in increments of 30,000 after that. My car has never went into limpmode, But nissan paid for a new transmission after I complained of a transmission "whine" (much like that of a supercharger, You could literally hear it from 500 yards away) so the changed the trans at 119,656 miles
. I am almost positive I know when I blew the transmission I was driving the car harder then I ever had before and the trans got hot.. Really hot... I was literally pushing the car to its maximum limits for about an hour and did multiple times after that. The trans never went into limp mode with me or threw a CEL, But when nissan took the pan off (when they replace it at the 119) they found chunks of metal and brass in the pan! The servicer on my car said he'd never seen anything like it and had no doubt in his mind that nissan would be covering the bill. The cvt is a fantastic transmission it just needs a little help, The overheating issue I think becomes more apparent and harder to resolve after the first few times you tach your coupe to its limit. I have in most cases stopped using tip mode all together to cut down on the trans load.
