First time w/drag radials: any tips?
cullenj76
Car: 99 Q45t 04 SRT-4
went ahead and bought some bfgoodrich g-force drag radials(205/50-15) for the maxima to help put some newly found power to the ground. Any tips on pressure, heat cycling(if needed), etc.?
Exar-Kun
Car: 2005 350Z
warm them up, and drop air pressure to 26psi for a baseline run.
Thats an awefully short tire for a maxima, and Im sure the load index isnt built for the car.....why such a small size?-chet
cullenj76
small diameter is one reason for the size, another is that it is the only drag radial that would fit a 15x6.5 wheel. the load index IS ok by the way.
thanks for the tips
