sepulchralx »
https://forums.nicoclub.com/sepulchralx-u31312.html
Sun Feb 01, 2009 5:50 pm
Darius:
I redid my wiring, you were right the eccs relay wasnt getting power..
I unravelled every freaking thing heres what i found and then the results:
Findings:1. the ecu plug's eccs main power source to the relay was missing; the orange wire was actually in pin 17, and not 16, for some weird weird reason. I repinned that on the ecu plug to go to pin 16.
2. I went through all my wiring twice, looking at ecu plug diagram and the writeup for rb in s14.. everything was good.
Results:
Now when i hook battery up the cluster lights don't come on, so that problem is solved. when i turn the key the lights come on and nothing happens.. I hear the fuel pump priming now, and the power to the eccs relay is on good. I am getting power signal from F3 pin 1, ( ignition lead to injectors) and power from F3 plug 34, (start signal) and nothing happens. Its like the starter doesnt want to kick over or anything.
I've tried starting the car with clutch interlock jumped and unjumped. I believe that the fact that the start signal is travelling through the harnesses is a good sign.. it means i'm narrowing down my issues. I still have high voltage and my fuses are good... not sure about my relays... I dont know if the starter solenoid is even getting any signal. What should i look into next??
Modified by sepulchralx at 8:14 PM 2/1/2009
