First time running CA at the Track
Oneor1
Car: cars, music, hockey
well just got in from Richmond Dragway about 10 min. ago....... heres how i did
my first run i spun horribly and ran a 15.096....i decided i needed to burn out better next time im in the burnout box and get all that damn water off my car
my next run..... went much better.....
Reaction - .67960 Ft - 2.37071/8 ET - 9.56731/8mph - 76.361/4 ET - 14.6871/4 MPH - 96.73
i was hoping to run in the mid 14's and i succeded...... what do you guys think about the results?? let me know
mods are:NPR FMICTurboxsRFLGreddy DP to STOCK exhaustCA16 camsstock boost3 puck clutch
take it easy
-Rick:ylsuper
Xero
oooohh...stock boost, and stock exhaust? nice!!
chezina
Good result ! Especially for this setup.What tires did u use ?
Oneor1
i used some BF goodyear or something....nothing special 215/40/17.... launched at about 3k
Guffed
Car: cars and girls...What else is there??
Yeah, pretty much that's how my set up is (Intake, exhaust, 3 puck clutch, Gizzmo reprogramed ECU, and a bov) and I haven't been up to my track yet so I was wondering what I might run. I was guessing 14's too but hoping for low 14's...(My swap isn't even done, 99% though, all I need is a harness...)
Altiman94
Car: 1989 Nissan 240SX
mid 14's are good times from a lightly modded ca.
boost_boy
My first run was a 14.6@98mph as well with the tires breaking free and no lsd. I eventually ran a 13.9@103mph on my second run when I let some of the air out of the tires. Good job, and 14.6s is normal for a light modded CA.
Nismo1182
Car: Z06
damn 14.6 at stock boost:eek:
I wonder what I would run when I ran 15 psi on the stock sidemount, stock SR downpipe to 3" exhaust.
I know I did beat a mustang that did high 13's and smoked a 99-00 hatch with a type r motor who said he ran 14.4
I popped the head gasket for running that amount of boost on the side mount.
Headgasket is getting replaced with a tomei 1.2 mm one, getting 440 injectors, S14 SR T28, AFC-2, big *** FMIC, race clutch, wider tires and 3" downpipe.
Im going to run 15-17 psi and im hoping for a really really low 13 to high 12 :D
boost_boy
Quote »I popped the head gasket for running that amount of boost on the side mount.[/quote] Tell the truth, did you pop it or burn it?;)
Oneor1
hey dee, any chance I can talk to you on AIM sometime?...got a few questions for ya.
boost_boy
Sure, I'll log on now for a few!
Nismo1182
Car: Z06
boost_boy wrote:Tell the truth, did you pop it or burn it?;)
Havent taken the head off yet. Car still ran perfect, I just keep loosing coolant on the exhaust side by the turbo. No oil in the coolant or vice versa.
So now im going to do things right instead of half-assed.
float_6969
Posts like this just make me wanna put mine in all the sooner... I got the motor outta the clip today and found out I get to replace the rear main seal, yea! At least mines eaiser to do then a head gasket...
Nismo1182
Car: Z06
My motor is out of the car :pface
float_6969
Well.... Mines still eaiser!
boost_boy
now, now kids:D
float_6969
He started it!
boost_boy
Both of you, put your heads downs and think about what you two have started (I loved when my teacher told me that; can you say wake mu when class is over:D ).
Nismo1182
Car: Z06
boost_boy wrote:Both of you, put your heads downs and think about what you two have started (I loved when my teacher told me that; can you say wake mu when class is over:D ).
Hey Dee,
I dont know if I remember correctly, but didnt you say before that the ARP headbolts dont fit correctly. The top I mean.
Im going to be replacing the headgasket soon and I was debating on getting new stock head bolts or ARP.
What headgaskets do you use? And how much? I'll probably end up ordering a HG thru you or something.
boost_boy
I talked to the folks at ARP and they want me to return the 6 point nuts that they sent me and they'll send me some 12 point units that require a smaller socket. I'm using a NISMO headgasket in my built engine and using the stock headgasket that came with the motor in my girl's CA. I also have a 2mm copper unit that I'm saving if the NISMO piece can't take it (which I seriously doubt).
NeedCAforS13
Car: CA swapped S13 coupe
Dee you got another 2mm gasket layin around you wanna sell me;) or where can I get one QUICK! I'm coming down Sunday (FOR SURE;)) but I'll call you thursday to confirm!
Sean
float_6969
Sorry Dee, I've been bad. Will you spank me? I mean... Dude, your sick, you wanna spank me!!! What a perv! Hehehe
boost_boy
No extra gasket on hand as that one was saved for a rainy day, but if you need a copper one, it came from a company called "ridgecrest" in Australia and info can be found on them via a simple net search. Likie I said a while ago, all of these parts except the NISMO H/G came in a care package from Malaysia.Quote »Sorry Dee, I've been bad. Will you spank me? I mean... Dude, your sick, you wanna spank me!!! What a perv! Hehehe[/quote] I ain't spankin' no man, float:D
Nismo1182
Car: Z06
how much was the Nismo HG?
boost_boy
The NISMO gasket cost me around $280 about 3 years ago. It's been just sitting and awaitng me to get started and that time has come. They're probably a bit cheaper now, but don't look for them to be too cheap as they probably are somewhat rare now.
