chad b. »
https://forums.nicoclub.com/chad-b-u120574.html
Sat Sep 15, 2012 3:46 pm
Yes, Chase Bays is garbage, I agree. So, I called Ricky at Raw Brokerage, and he told me the CAS was the problem, so I bought a new RB CAS from them and installed it on the motor. We were getting 10k rpm on turn over, so something was major wrong. I then took the AEM trigger disk out of the z32 CAS that I had and installed in into the RB CAS and reinstalled in on the motor. Now We're getting 250rpm on turnover, and spark, but no start. The plugs are getting fuel on them, so the injectors must be firing. We checked all of the injectors and coils from engine to the ECU plug to make sure everything was in the right place, and it is. I also did a compression test to make sure the valves were closing. The compression was dead on across all 6 cylinders. So, now I'm starting to think the CAS wires must be wrong. In the AEM paperwork, it says that the 2 shielded wires on the CAS go to CAS signal and CAS sensor. One reads like 0-120 degrees and the other reads like 121-180 or something like that, I don't remember exactly, and they go in pins 41 and 42 on the AEM and jumper to 51 and 52 which are the power and ground wires (unshielded) on the CAS. I was told that if the AEM doesn't see at least 500rpm at cranking, it will not start the startup sequence. The motor is turning over very fast, so I'm starting to wonder if the two wires (pins 41 and 42) are crossed up, causing it to read the trigger disk incorrectly.
Does anyone have the wiring colors for RB CAS, Z32 CAS, and Neo Hitachi CAS?
I may have the same problem 95_240 was having.
