First time posting & want advice
q45_owner
Car: 92 Q45 w/TCS
:) Hey first post! Anyways, I was wondering how a 92 Q would fare against a 95 manual Honda Prelude in the quarter mile?Because a friend wants to try me with his other friend who has pretty much the same car he has (a prelude) this friday in light of his birthday. :confused:
Q45tech
Depends on condition of transmission and engine ........the 92Q will cover the quarter in 15.2-15.6 seconds normally depending on temperature and elevation [baro pressure].http://www.syclone.freeserve.co.uk/rivals.htm
Pretty much equal depending on driver.Tell us which one is faster after the race.
Q451990
Speaking of engine condition... run a search on "Chain Guides" or "timing chain guides" - welcome to NICO!
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
One has to wonder why compare a 4 cylinder, two seater, ton and a half car with a manual transmission to a two ton, four seat, V8 automatic luxury car?
Must be dull times in Kansas City.
Gotta have something to do. :)
The latest V6 Accords will run to 60 in 6.2sec. Wonder what the numbers are for a mid-90s Prelude. Did you check http://www.car-stats.com?
Altiman94
Car: 1989 Nissan 240SX
It depends on the model. S-vtec, si, or just the s.
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Altiman94 wrote:It depends on the model. S-vtec, si, or just the s.
:yesnod
F23, H23 or H22 engine?
It's on a flat spot on the engine facing the front of the car, right where the trans bolts up to the engine, just above the oil pan.
q45_owner
Car: 92 Q45 w/TCS
Well the one I'm going to race is an 2.3 si. If I raced my friend I would be racing against a 2.2 VTEC H22 engine- he has a custom cold air intake. Its gonna be on a drag strip a 1/4 mile run... I'll probably wait for my engine to cool down 30min to a hour before I do other runs. I've checked this site: www.missouri.edu/~apcb20/times.html for 0-60 and quarter mile times and it seems it'll be about even.:)
q45_owner
Car: 92 Q45 w/TCS
Yeah, also I did read up on this chain guide problem- thats a big concern. I have 141,800 mi on my car now... I got it in March with 139k. My transmission was replaced in 95' by the previous owner when it must've went bad (service record)- replaced with 92' transmission cause it starts in second gear. From what I've read I need to get new chain guides and a transmission cooler soon.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
q45_owner wrote: From what I've read I need to get new chain guides and a transmission cooler soon.
Most definitely! It will be a real bummer if your engine craters, even if you "win" the race. Good call on the dragstrip.
Do a little more reading here and you will realize a short time ago 3 1992 Q45 were lost due to timing chain guide failure within a 6 month period on this board alone!
Check out NICO's articles section for some info on chain guides. transmission coolers are cheap too. Mine was $100 installed. Wes has a how-to guide at http://www.q45.org if you want to install it yourself.
-Jesda
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Jesda wrote:Check out NICO's articles section for some info on chain guides. -Jesda
Uh, yeah, and please do it before you go to the track.
:D
Even with the H22, I say you'll take him. Providing your car is in good tune, even just the basics.
q45_owner
Car: 92 Q45 w/TCS
It seems the most I can do before the race is to remove the cover over the chain guides and see if it is starting to crack and show wear...(funds). I will take of that as soon as I take care of the power steering pump and hoses which are busted but the dealer said I could drive on for a while. They're charging me $1,300 and I've been driving for 2 months already which has me worried. I only need to take care of 700 out of that amount- the rest is covered. This all tells me to put aside the race and take the bench... for a while.:(
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
I just finished a new fan clutch, radiator, hoses, p/s pump rebuild, p/s lines, trans lines & p/s cooler. trans cooler.
There's a lot of stuff to do in there, I know the quote is high, but it's time consuming.
