gearzablade »
https://forums.nicoclub.com/gearzablade-u270833.html
Mon Mar 06, 2017 8:06 pm
Hello
I decided to pull my motor and I'm having some question that I would like to ask. This is my first time pulling any engine out so please bear with me if it a "dumb" question.
I took out the radiator, unplugged every cord and hoses so far. The only thing I need to get to are the motor mounts, alternator, AC condenser (The medium size block at the bottom right? There is a hard hose connected to this. from the right that runs to the left, how should I go with this?), and the transmission bolts.
1. I'm only trying to take out the engine only, will I still have to drain the transmission fluid?
2. Are the 10-12 Transmission bolt the only bolts holding on to the transmission to the engine? If so, once I take them out, do I just pull the engine to the front and pull it up with the hoist?
Thank you
