First time go
Sabot
I'm like days away from starting my sr for the first time and I'm kinda scare cuase usually all I read here is trouble when starting for the first time. I want to find out how many here SR's started the first time you turn the key, now I know you might needed some tuning for the sr to run right but if it started first time I want to know.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
mine worked fine the first time, just had to fix the time before it would actually start... was around 160 degrees of lol. soon as we got that fixed it ran great!
S13FASTBACKSR
Car: '92 Fastback SR powered
same here mine was good just got to do the timing adjustment maybe idle adjustment as well..i checked my tps voltage at idle as well
fregisr
Car: 240sx 1990
Sabot wrote:I'm like days away from starting my sr for the first time and I'm kinda scare cuase usually all I read here is trouble when starting for the first time. I want to find out how many here SR's started the first time you turn the key, now I know you might needed some tuning for the sr to run right but if it started first time I want to know.
Just remember to disconnect the CAS, and let it crank for a few seconds to get the pump going and lubricate everything, also make sure the oil pressure light goes off before you try starting it.
Sabot
Cool
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
fregisr wrote:Just remember to disconnect the CAS, and let it crank for a few seconds to get the pump going and lubricate everything, also make sure the oil pressure light goes off before you try starting it.
disconnec the CAS, then crank for ~20 seconds. if the oil light doesn't go out, crank it again for ~20 seconds. continue doing this until the oil light goes out, then do it 1 more time just for the heck of it. mine took a good 2 minutes or so of this, so don't get discouraged. it's important to get plenty of oil into the valvetrain, turbo center section, etc. so you don't end up with a bum lifter or worse . . .
TougeSlide
Car: Sr powered 240sx
first turn of the key after i primed the oil.
SDS13COUPE
Car: 89 Pignose
YUP YUP...AFTER THE PRIMING AND TIMING, SHE RAN LIKE A CHAMP...
