First time drag racing my S14
Ace
Car: S14
It was an interesting day and a safe way to get rid of building adrenaline. Unfortunately (for some of those muscle cars that is) I will not be drag racing anymore. Due to my relocated battery I must rig up an outside kill switch but since my car is a street car I don't want to do that. I just wanted to see what the car would do. I'll stick to auto X.
I raced 5 times the cars were a old 60's Chevelle SS, an old 70's (i think) camaro, a basically stock 240, a 5.0 Mustang, a new Neon SRT-4. Fortunately I was able to beat them all.
My best time was a 13.775 @102.57. My fatsest trap speed was a 103.31 when I ran the camero. I totally bogged the motor aginst the camero and he jumped ahead by .2 seconds but I reeled him in and took him in the end. It feels awsome when you start to pull on a big V8 what all you have is a 2 liter.
BTW best slip rundownrt .45360' 2.210330 5.9301/8 8.974mph 81.331000 11.5741/4 13.775mph 102.57
That was against the 5.0 Mustang who ran a 14.080 @ 97.02
Mod listS13 SR20DET BlacktopGreddy R-SPL FMICHeavy Throttle Stainless Test pipe and DownpipeHeavy Throttle HotpipeBlitz Nur Spec R exhaustACT 6 puck clutchWalbro 255 Fuel pumpHKS intakeBlitz BOVPermacool electric fan with adjustable thermostatNGK Iridium spark plugs heat range 7S14 SE VLSDHKS EVC V Boost controllerGreddy full auto timerGreddy 52mm Electronic Boost and oil pressure gaugesJIC Front Aluminum strut barJIC Rear Aluminum strut barKoyo Aluminum JDM radiatorKoni adjustable shockseibach sportline springsAuto-Manual swapRealocated battery to trunkNO A/C or ABS195/60/15s Toyo spectrums all around on stock Nissan wheels
I wish I was able to use the 300ZXTT wheels that I had in my garage but the 5 lug swap is needed first. I didn't launch very hard at all, in fact the time that I bogged the start against the camaro I still ran a 13.8 at 103. So with good launches I believe this is a 13.5 car.
I was running 92 octane pump gas and .9 bar for boost
RobDET
Car: Cars
I have a kill switch too... And H8 showed me where to put it
http://www.nissaninfiniticlub....witch
Ace
Car: S14
behind the liscense plate what a concept. Great idea I guess I will continue to drag race. V8's I'm back.:D
HolyShiznit
Car: Working on my car
Whoa Ace that is very nice indeed, you have a lot of work into that SR imo. Those 195 tires aren't exactly helping either, getting some meatier ones and stickier ones and you will do much better, also your 60' s if you can get them down to 2 flat or better you will be low, low 13's. Good job.
Ace
Car: S14
Hey I know you from NWN. I am FullRunS14 on there. Anyway if you read the bottom of my first post you would see that I have some 300ZX TT wheels which are 16x7.5 in the front on 225/50/16 and 16x8.5 in the rear on 245/45/16 I just need to swap to a 5 lug hub before I can mount them. Yeah I did have a fun time doing some dragging. So a good mix of auto x and dragging would be nice. Later
Rob
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
Very nice! Hopefully I will be able to turn some similar times. Except I will be running an s14 Sr @ 10psi until I can get some bigger injectors.Yeah, just get something wider in the rear with DOT drag radials and you'll be in at least mid 13's
