first off the archives provided some good information.
Now I'm starting this thread incase I've missed some good pointers that were buried in threads that my searches never hit on.
I know to jack the car in the rear with jackstands, that the front dosen't need to be raised.
I'll drain the transmission fluid and the hydrualic clutch fluid.
remove shifter in side, then take off all bolts on the bellhousing
Disconnect the driveshaft at the diff end - then it slides out
Any quick hints and tips you can give that you don't think I've stumbled across in my searching would be much appreciated.
*keep in mind that...
I'VE NEVER DONE A CLUTCH INSTALL BEFORE
you help is appreciated!
thanks,
lbrowne
ps : getting an oem clutch kit from NAPA that has the release bearing, pressure plate and clutch.
