From the '06 M45 Service Manual which is probably not too far off from the '08 (just need to follow links for your year's service manual in Ilya's sig)
Wheel Nut Torque specs: 112.6 N-m (11 kg-m, 83 ft-lb) from Maintenance Section: MA
Torque Member mounting bolt (caliper bolt) Front, Torque specs: 132.5 N-m (14 kg-m, 98 ft-lb) & Rear, Torque specs: 84.3 N-m (8.6 kg-m, 62 ft-lb) from Brake System Section: BR
Funny, I just make sure they're tight.
