tires are BFG drag radials that i borrowed from my buddy that owns a TT G35..stock 18inch G35wheels too...no sidewall at all on them radials..i didnt get them hot enough aparently..next though ..next time.cdorhout wrote:Looking good! What kind of tires are you running?
Yeah I always had trouble getting my BFG's hot in the box, I think its got a lot to do with the light weight of our cars. Buy some 15-16 in mustang, or rx-7 wheels, and get some BFG"s on those. More slide wall flex. I'd do a burnout in 2nd gear as well, more rotations = more friction = more HEAT!S14-NEO wrote:
I see, your trap should much higher than that if the boost stayed the same.... Like 120 to 125 I'd imagine..... Definitely missing something.S14-NEO wrote:the turbo is a 60-1...as far as power i had it dynoed on a mustang dyno at Japtrix, she made 430whp at 16psi
yeah i totally agree with that...ill get another shot at it once i get my new axless that i wont have to worry about breaking..Shocker wrote:
Matt, what has Chad run thus far with his 30r setup? Or did he break to?
well i am getting a skyline rear diff and axle setup..shouldbe more than enough to taek care of what i want to do..and when i go back i will be on slicks the next time...there wont be any more traction issues..lolrb25drag wrote:HAHA!! Don't you hate those dang Stock axles? Which ones have you decided to go with? Also are you on a Posi or Lsd?
Also if you want traction get the M:T Et streets, You won't be Dissapointed. Other than for Too much traction. Which Causes Bogging on the line and then your going to want a launch control to put 100 more horses at the launch to get that baby Rollin!! Its a Disease!! once you start making good power and turning good numbers you can't stop till something stops you!! LOL. I have problems with my car dropping boost in 3rd gear also!! I have yet to figure out why tho. I have a Manual boost control with the Electronic solenoid so I can switch back in forth from the stock waste gate.
Copy cat....cdorhout wrote:Actually I did a search today for some cheap OEM 15" Mustang wheels to put some DRs on. Am I predictable or what
My best trap speed on my 3076r was 120mph. That was with very bad traction off the line though.
