First Synthetic oil change! WOWWWWWWWWWWW!!
Dubzino
Car: 2001 Infiniti I30
Well I decided to change my oil to synthetic oil today. I went with mobil 1 in my 2001 i30 and she loves it. As soon as I took it out I could notice the difference right away. Idle is so much smoother now . I dont knwo what took me so long to make the switch. Another satified customer!
Welcome aboard!
Good call on the full-syn, these motors do very well on it.
Pics of the I30?
Fenvy
Car: 2005 350Z Base 6MT
when is the last time you changed your oil? it could be the placebo effect but nevertheless the switch is always good
I personally do not like mobil1 since it feels so thin... a lot of members here use royal blue or redline with good sucess
you can get redline at myoilshop.com
Mister 26
Car: 2000 Infiniti i30t
A friend of mine who is knowledgable about cars always warns me to stay away from synthetic motor oil because they will leak through the seals in the engine.
Comments?
maxhopper
Car: 02 Maxima SE 6spd
That is false. My Maxima has about 160k miles on her, and it has had Mobil1 synthetic in it since 30k miles. No leaks, no oil consumption.
Mister 26 wrote:A friend of mine who is knowledgable about cars always warns me to stay away from synthetic motor oil because they will leak through the seals in the engine.
Comments?
There is *some* truth to that - Synthetic oil CAN leak where no previous leaks were apparent.
However, that's often in cars that switch after a TON of miles, and have bad seals to begin with. At that point, switching to full-syn really doesn't make much sense anyway.
As we always tell people, the BEST oil is CLEAN oil, regardless of what type. Synthetic simply offers a small additional measure of protection at the "ragged edge".
Fenvy
AZhitman wrote:As we always tell people, the BEST oil is CLEAN oil, regardless of what type. Synthetic simply offers a small additional measure of protection at the "ragged edge".
in addition, synthetic oil is supposedly better against thermal break down. I don't know any turbo folks running non- synthetic
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
AZhitman wrote:However, that's often in cars that switch after a TON of miles, and have bad seals to begin with. At that point, switching to full-syn really doesn't make much sense anyway.
You think my ~208k miles might put my car in this position? I was planning to switch to full synth with my next oil change.
Meanwhile, the A34 had it's first taste of synthetic last weekend.
Nope - I'd stick to dino juice with that many miles.
chris322
Car: 2001 infiniti i30
i just bought my i30 2001 and i was planning to switch to redline but what do you guys prefer to use 5w-30 or 10w-30 i live currently in Guam so its 80f-100f degrees everyday which would be best
Hey Chris, welcome to NICO!!!
I'd recommend the 5w-30 for sure.
Glad to have you aboard!!!
chris322
thnx man, jus got the car a couple weeks ago and love it already.
Mister 26
so would you folks say that a VQ engine with 90K miles is or isn't a good candidate for synthetic motor oil?
maxhopper
I guess it would depend on how regularly maintenace has been done over the life of the car, the amount of abuse it's seen, and whether it has sat undriven for long periods of time (which would cause seals to dry out).
You could always give it a try, and switch back if you develope any leaks.
Mister 26
I just bought the car with 89k miles but with no maintenance history. The dealership that I bought it from told me that they had the maintenance records but destroyed them to protect the identity of the previous owner. How frustrating is that?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
Mister 26 wrote:I just bought the car with 89k miles but with no maintenance history. The dealership that I bought it from told me that they had the maintenance records but destroyed them to protect the identity of the previous owner. How frustrating is that?
smells like bull**** to me.
how about just ripping the owners info off of the receipt?
my vq30 has 96k miles, and i use 5w30 GTX. OCI of 3k miles
I35sport
Car: 2002 I35 Sport
My 2002 I35 has 93K miles & has used synthetic since 3K miles. When approaching 100K on my 2 previous cars (each purchased used at about 45K miles) I started using Slick 50 and noticed smoother running. on a VQ engine, is use of Slick 50 overkill - or low cost insurance for longer engine life?
P.S.: Are Brembos for the I35 overkill?
Modified by I35sport at 9:11 AM 6/28/2006
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I35sport wrote:P.S.: Are Brembos for the I35 overkill?
Better brakes are never overkill.
Not a fan of "Slick50" and other "snake oil" additives...
Brakes are a good call tho!
Welcome aboard!
C-Kwik
If you can run synthetic witout leaks, then synthetic would be the better option. But it would be a pain to have te replace a lot of seals if it couldn't hold it. If you wanted to try it, you might try a slightly heavier weight then you normally would. One of the big pluses to using synthetic is it's detergent properties. pull a valve cover on a motor that's been running synthetic for a while and there will be no build-up. On Dino oil, you can expect some varnish. I just put in a quart of synthetic in my 137K max and I'll be checking the seals soon. Hopefully it holds up and then I'll be making sure its on a steady diet of synthetic.
Eddie
Car: 1995 240sx se
I just changed to Mobile 1 0w40 on a 170k ka24de and have no signs of leaks after 500 miles hopefully no leaks will arise. It's no maxima, but just giving some feed back. Before the switch the oil was changed religiously every 3k.
IvoryJ30t
im in the process of switching over...
i have mobil delvac1 5w40 in the vq30.
i changed at 99,750 and i have 99,905 right now.
mobil 1 comes at 102k
i noticed the difference immediately.
