Stripes »
https://forums.nicoclub.com/stripes-u76540.html
Fri Oct 10, 2008 3:05 pm
So I tinkered with a few things and it is running better now but still not right.It idles now, but at around 2k. It will idle for about 30 seconds or so and then it dies out, like the fuel pump quits or something. Also, if I hit the accelerator it will die. It's acting like the fuel isn't putting out when air comes in.
What we've thought of so far is....The tps reads a voltage based on the position of the throttle body. Right? So what I'm thinking is this voltage reading gets sent to the ecu, then to the fuel pump, ultimately telling the fuel pump to give it the right amount of fuel for the amount of air that is coming in. So if this is right, then the only thing I can think of right now is that for some reason the fuel pump is not getting the correct voltage reading to pump more fuel, which is why when I give it gas it dies out.Now, I cut the pink and black wire coming from my fuel pump relay and grounded it with a switch because for some reason the fuel pump was not getting power with the wire routing the way it was. I don't think this could be the problem but I figured I'd let you guys know
