Razi wrote:One is for the regular vacuum.The second is supposed to be hooked up to a boost source, supposedly it helps the BOV open faster. You can put one of those small cone filters from Autozone if you'd like, just don't plug it.
I'm glad I asked, because I was thinking of pluggin it... lol
If I were to use that port, I guess any source of boost such as a hot pipe port or somethingwould suffice right?
spooled240 wrote:cool beans
what size turbo is that and what are you using for tuning?
Make sure your engine is running perfect with no leaks or other problems before you start beating the hell out of it but it seems like you are doing just that.
That's a T3/T4 TO4E 50 trim, it's a no-brand "generic" turbo (I know, I know... I also have a Garret $$, but that baby is not going in until I feel comfortable and knowledgeable enough on boosting the KA, then I'll go with the Garret, 550cc, JWT ECU and a turbosmart WG set at 15psi . For now, this is my "lab"). It brought an external wastegate set at 7psi, but I heard it open before 6psi when I was in third gear; which is fine, since I want to take baby steps on boosting anyways.
As far as tuning I just have the Walbro 255 and the 8:1 FMU with the stock injectors. My car won't see anything over 7psi for a while. Nevertheless, as soon as I get my silicone reducers and put the front mount I/C I want to take it to the dyno to see my A/R's and whp
turbo bells, turbo bells, turbo all the way....
BTW, that's a clean kouki man, and I like the extra cooling on the I/C, too bad we don't have that in Florida
