I just got my first "complimentary" oil change - got a receipt!
On the Recall question.
These are the only two Recalls for the 2007 Versa...
Make : NISSAN Model : VERSA Year : 2007Manufacturer : NISSAN NORTH AMERICA, INC. NHTSA CAMPAIGN ID Number : 06V348000 Mfr's Report Date : AUG 31, 2006Component: SERVICE BRAKES, HYDRAULICPotential Number Of Units Affected : 13184
Summary:CERTAIN SPORT UTILITY VEHICLES FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 135, 'PASSENGER CAR BRAKE SYSTEMS.' THE BRAKE FLUID RESERVOIR CAP IS MISSING PART OF THE REQUIRED BRAKE FLUID WARNING.
Consequence:THE PURPOSE OF THIS STANDARD IS TO ENSURE SAFE BRAKING PERFORMANCE UNDER NORMAL AND EMERGENCY DRIVING CONDITIONS.Remedy:NEW BRAKE FLUID RESERVOIR CAPS WILL BE MAILED TO VEHICLE OWNERS ALONG WITH INSTRUCTIONS FOR INSTALLATION. THE LETTERS WILL INSTRUCT OWNERS WHO DO NOT WANT TO REPLACE THEIR OWN BRAKE FLUID RESERVOIR CAP TO TAKE THE CAR TO A DEALER FOR THE REPAIR. THE RECALL BEGAN ON NOVEMBER 10, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes:CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV.
Make : NISSAN Model : VERSA Year : 2007Manufacturer : NISSAN NORTH AMERICA, INC. NHTSA CAMPAIGN ID Number : 07V094000 Mfr's Report Date : MAR 07, 2007Component: SEAT BELTSPotential Number Of Units Affected : 16309
Summary:ON CERTAIN HATCHBACK VEHICLES, THE TERMINALS FOR THE PASSENGER SIDE SEAT BELT TENSION SENSOR HARNESS CONNECTOR MAY HAVE BEEN DAMAGED DURING THE MANUFACTURING PROCESS. THIS COULD RESULT IN A LOSS OF ELECTRICAL CONTINUITY CAUSING THE OCCUPANT DETECTION SYSTEM TO BECOME INOPERATIVE.
Consequence:IF THIS OCCURS, THE AIR BAG WARNING LIGHT WILL COME ON AND THE PASSENGER SIDE FRONTAL AIR BAG WILL BE SUPPRESSED.
Remedy:DEALERS WILL REPLACE THE CONNECTOR FOR THE SEAT BELT TENSION SENSOR HARNESS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT JUNE 18, 2007. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes:CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO
These are the only three Technical Bulletins for the 2007 Versa...
Make : NISSAN Model : VERSA Year : 2007Manufacturer : NISSAN NORTH AMERICA, INC. Service Bulletin Num : 07038 Date of Bulletin: JUN 05, 2007NHTSA Item Number: 10021702 Component: WHEELS:CAP/COVER/HUB
Summary:WHEEL COVER REPLACEMENT IF THE WHEEL COVER DOES NOT FIT FIRMLY ON THE WHEEL. *KB
Make : NISSAN Model : VERSA Year : 2007Manufacturer : NISSAN NORTH AMERICA, INC. Service Bulletin Num : 03030 Date of Bulletin: APR 18, 2007NHTSA Item Number: 10021508 Component: EXTERIOR LIGHTING
Summary:EXTERIOR LAMP FOGGING. *KB
Make : NISSAN Model : VERSA Year : 2007Manufacturer : NISSAN NORTH AMERICA, INC. Service Bulletin Num : 06078 Date of Bulletin: NOV 08, 2006NHTSA Item Number: 10020596 Component: TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
Summary:TIRE PRESSURE MONITOR SYSTEM (TPMS) LIGHT ON WITH CHECKSUM-EER FL / FR / RR / RL CODE STORED. *KB
