boystar22 »
https://forums.nicoclub.com/boystar22-u104360.html
Sun Mar 15, 2009 5:30 am
I would have to agree that it's probably very shotty work from the dealer, but keep in mind that you will loose more oil between changes when your under the break-in period because all the seals and rings are new, so they will absorb some of the oil at first. The dealer probably didn't fill it up full, but it might not have been filled quite as low as it is now. But I do agree, thats pretty bad service work especially to leave the shroud covered in it. I have to take the shroud off the engine to fill it since the fill cap is so recessed, but I'm sure the dealer has the hose dispenser.
