pdqwrx »
https://forums.nicoclub.com/pdqwrx-u28270.html
Fri Aug 12, 2005 8:01 pm
Just out of curiosity, did you reset the ECU on the car? The idea behind the intake is to make the induction of air more effecient and in the end helping milage. If you didn't reset the ECU though it will still be running a program "Learned" through years of driving. To reset it you should disconnect the negative battery terminal for about 30 min and step on the brake pedal for 30 sec or so. You can also leave the parking lights on. The idea is to drain all the capaciters the computer and various circuts that might hold a charge. Just an idea, then drive it for a week or so and let it re-learn your new intake.
LaterScott
