MWARMY »
https://forums.nicoclub.com/mwarmy-u151987.html
Thu Dec 08, 2011 9:59 pm
hey guys and gals im having some issues getting a fresh rebuild to start i put in my 240....needless to say the cars been around the block a few times. its had an rb, sr and 2 different ka's insstalled in it thoughout the p.o's . its also an auto to manual swap. the ac and ps has been removed and hicus deleted as well. dual altima fans have been wired into the ac relay with a temp switch to cool the aluminium radiator. emissions have been removed and ive got a msd blaster 2 with ballast resistor for my coil. the issue im having is when i crank the engine it turns but doesnt fire. ive check for fuel and spark and im getting both. i removed the spark plugs and they're soaked in fuel. checked fuel pressure and its at 45psi when i turn the key to the on position and after a second drops to 42 during cranking 38. i pulled the injectors and put them in an extra fuel rail and hooked up the fuel lines to watch them fire when i cranked the engine. when its cranking all the injectors fire at once i guess this is called batch firing which the ka does when it tries to start. (from what ive read at least..) it seems lik there is an excesive amount of fuel coming out of each injector when it fires, i took the dizzy out and spun the gear at the end of it, with the key in the on possition and each injector fireds individualy a little pufff of fuel way less than what came out during cranking of engine. i checked the ecu for any codes and the only one i get back consistanly is 34.. knock sensor. i have gotten quiet a few times the no ignitions signal present in the primary circit error code (21 i believe) but not everytime after ive reset it. ive gotten the engine to pop a couple times when i start fresh for the day and the spark plugs are dry, but thats it. it floods b4 it will turn over completly. timing is correct ive checked as well as a friend thats been helping witht the build. oh yea and i swaped ecu's coolant temp sensors ignition control module and the dizzy. unfortunatly the parts that were changed wernt all new some came out of the junkyard and some out of other running 240's. oh yes and theres more ( i kno completely molested) there was an alarm in the car, i removed it but some of the alarm harness is still under the dash. i found at least one wire from one of the stock dash harness plugs that has been spliced to the alarm harness.
