Normally you want to stay away from K&N because many people who have had them have had burned out MAF sensors due to the oil on the air filter. You are supposed to stay away from any air filters with oil on any car that uses a hot wire type MAF.SwayMan512 wrote: ↑Tue Aug 15, 2023 12:47 pmRight now I'm between a K&N intkake https://www.z1motorsports.com/air-intak ... 28095.html and the Injen Intake you recommended me. Trying to see if there's really any of a differnece, including the sound.
For the Kinetix VQ35DE Velocity Manifold, I've heard some reviews such as the Manifold cracking and or doesn't really add as much as a performance boost and that I would be better off with a spacer. I would like to ask how you felt about your Manifold and if such things are common. I've watched videos and looked in other forums and it seems pretty middle ground when it comes to just getting a spacer or Kinetix Manifold. Later on in the future, I may go FI but I'll see how things play out with the help you've provided me. Do you have any pictures of your car and engine bay? I'd like to see the work you've done with your car. I don't see many M35 builds.EniGmA1987 wrote: ↑Mon Aug 14, 2023 3:25 pmWhen you start doing performance, dont forget reliability mods as well. You should add a transmission cooler and an oil cooler to drop the temps on those areas. Extra heat will kill those things faster.
https://www.z1motorsports.com/transmiss ... 98ac4bee25
https://www.z1motorsports.com/z1-produc ... 1d56a868ad
Run an oil catch can to keep oil from being burned too much in the engine and keep things cleaner:
https://www.z1motorsports.com/z1-produc ... de6a273de9
Once you start getting into engine upgrades, start off with a crank girdle to strengthen the engine block, and replace the oil pump gears to ones that are far stronger:
https://www.z1motorsports.com/lubricati ... 8952caf615
Don't forget to reinstall some baffles when putting the girdle in, to help keep oil from sloshing around.
The oil pump gears are usually the first area of failure at higher than stock RPM, and it was something Nissan replaced with their VQ35HR version of the motor. It is a known limit.
The first engine part to fail horsepower wise is the connecting rods, but those are good to about 400HP, so not an issue unless you are going forced induction (turbo or super)
The block being made of cast aluminum also doesnt handle high RPM well or going forced induction, so the girdle adds some strength to the block for all future upgrades.
Those engine reliability upgrades will let you run higher RPM on the engine safely, so with a tune you can set your max RPM to 7250 instead of 6750. Dont do it all the time, as without replacing the entire oil system you will still run into starvation problems that high of RPM, but it will be fine to do it to show off here and then and for dyno runs.
In order to unlock even higher RPM than that, you will need to replace your valve springs. You are already going to be nearing the edge of valve float at 7250rpm with the stock valve springs.
https://www.z1motorsports.com/camshafts ... 79b9ae98fa
https://www.z1motorsports.com/tools/jwt ... 4f9aad1cd7
https://www.z1motorsports.com/z1-produc ... 4f9aad1cd7
Though to really make any more above 7000 RPM you will also need to either do some serious mods to the OEM upper and lower plenum, or replace them entirely with a far superior intake manifold:
https://www.z1motorsports.com/intake-up ... bda87c27f5
And a slightly larger throttle body to go with it for increased airflow:
https://www.z1motorsports.com/z1-produc ... edTogether
If you want to add some more performance while you are in doing valve stuff then replace your camshafts with these:
https://www.z1motorsports.com/camshafts ... d8242680a0
Then change some pulleys to lightweight models and do the idler pulley delete mod so that the engine can rev up more quickly due to less rotating mass:
https://www.z1motorsports.com/z1-produc ... c72b3bb6b6
https://www.z1motorsports.com/pulleys-a ... c72b3bb6b6
These will slightly increase HP by cause less loss in the engine, but also a faster rev will make the car feel faster as well due to being more responsive.
Once you finish all that performance stuff if you decide you want more your next step would be to decide whether you are going for really high compression ratio and stay NA, or just go FI with it. They take you in two different directions as far as pistons and rods, so you have to decide which way at this point.
Gotcha. Thank you for all the help! Means alot!EniGmA1987 wrote: ↑Mon Sep 18, 2023 11:39 amThe spacer from what I remember drops your torque in the lower RPM and boosts it in the higher. The whole new manifold is a smoother torque curve that gives a very minor (1-3HP) boost the entire RPM range, with an actual large performance gain (10-15) up in the 6500+ range. The velocity manifold also does a much better job of equalizing flow to all cylinders, so is better when you are going for big time upgrades and trying to get the most out of the car and its tune.
I haven't heard of any cracking issues, but I haven't really looked either. I know mine has been on for years and hasn't had a problem.
Appreciate you a lot! Might get all of this done during the summer! Did you do anything to your resonators??EniGmA1987 wrote: ↑Wed Dec 20, 2023 7:48 pmThe mufflers sound really nice on the car and add horsepower:
https://www.jegs.com/i/Jones-Exhaust/52 ... 5/10002/-1
https://www.amazon.com/BLACKHORSE-RACIN ... B07L57BBGS
And two of each of these just to make it easier for the shop to weld it all together nicely:
https://www.amazon.com/Stainless-2-5-Ma ... BKF1/?th=1
https://www.amazon.com/Apeixoto-Univers ... 08SC3FC6B/
And I believe these flanges are the size that comes with the OEM exhaust if you want the muffler to be able to bolt on and off the OEM exhaust:
www.amazon.com/Slmnliras-Exhaust-Connec ... 0C2C7G4TB/
A turbine muffler is a straight through design so you have less restriction in the exhaust, but it also uses baffles in a way to draw off slower moving exhaust to the outside and then allowing it to be reintroduced to the main flow to create a low pressure zone that helps suck more exhaust. This increase in suction is what helps increase horsepower by improving engine scavenging.
I actually have 3 different exhaust setups on the car. One is old, one I used to use at the track, and one is my street use. None of them are truly the masterpiece I wanted, but I just didnt want to drop an extra thousand to make my masterpiece. Maybe one day. lolSwayMan512 wrote: ↑Thu Jan 18, 2024 12:24 pmAppreciate you a lot! Might get all of this done during the summer! Did you do anything to your resonators??
Yooooo! Thanks for this, nice setup man! I'm still stuck between an H and or X pipe. I know for the H it might have a deeper sound and aswell as somewhat better in torque. But the thing is I can't find any video of an H pipe and how it sounds on this car what so ever!EniGmA1987 wrote: ↑Thu Feb 01, 2024 3:58 pmI actually have 3 different exhaust setups on the car. One is old, one I used to use at the track, and one is my street use. None of them are truly the masterpiece I wanted, but I just didnt want to drop an extra thousand to make my masterpiece. Maybe one day. lolSwayMan512 wrote: ↑Thu Jan 18, 2024 12:24 pmAppreciate you a lot! Might get all of this done during the summer! Did you do anything to your resonators??
Ill try and post some pictures at some point if I can find them still. But I use Vibrant Performance brand resonators (glasspack) on some and Jones turbine resonators on another setup. And actually, Im now remembering the other setup has some Flowmaster somethingorothers on it that I didnt like much. lol
edit: this was the design idea of one of my exhausts. I think my larger track one
