We just purchased a 1995 Infiniti J30 for well under $1000. That's the "good" news. Following is the bad news.
Miles: about 170,000
The crankshaft pulley seems to be about 1/4 inch too far in toward the engine block. All of the belts are way out of line. The only history I have on the car is supposedly the water pump was replaced about a year ago.
I'm wondering if a washer/spacer was not put back in at some point between the crankshaft pulley / harmonic balancer and the sprocket and that could be the cause of the misaligned belts/pulleys.
Here is an image of the problem:
Or for a larger image view the middle image at the top of this page: http://some-of-creation.weebly.com/1995-infiniti.html
I do have spacers on order from an Infiniti dealer.
The offset is so bad that the alternator bracket is throwing sparks from rubbing on the crankshaft pulley / harmonic balancer.
Also have transmission problems which I'll make another separate post about.
T
