theduster »
https://forums.nicoclub.com/theduster-u178726.html
Tue May 29, 2012 7:26 am
Hi, first post in the techincal section. I recently bought a 90TT Z. The car has some minor issues, mostly cosmetic, but I got it for a good price. I ran into a strange issue when doing the 120k maintenance and was hoping someone here would be able to point me in the right direction.
The problem.
Whenever I pulled the harmonic ballance off while disassembling the engine I noticed that it had been rubbing on the lower timing cover. I did the maintenance and kept that in mind while assembling everything. When the harmonic ballancer is installed and the crank bolt is torqued down the ballancer is about an eighth of an inch too far on the crank and does not line up with the accessory pulleys. Everything is back together correctly the best I can tell from looking at the assembly diagrams in the service manual. It seems to me like there should be a spacer between the harmonic ballancer and the timing sprocket (other then the thin gold collored one the holds the timing belt on), but I don't see one on any of the diagrams. Can anyone point me in the right direction? I'm really stumped here and any help would be greatly appreciated.
