First part for my turbo project are in......
Florida240sx
The man in the brown truck came to my house about 10minutes ago.It was raining and jumped out and came to my door.+1 for UPS man. Got my SAFC II from Injected.Been about 3 people recently who have had problems installign this.Can someone give a link on how to install correctly?Also I asked someone if it will remove rev limiter and was told no, but then in one of the threads recently someone said it will.Thanx.Also anyone know what I should put the settings at for now?Going to be stock for 2 weeks till kit arrives but want to get this out of the way.Thanx for your help.
jab11185
Car: 1992 Nissan 240sx
just leave the settings @ 0 across the board til the kits on....the ECU should compensate fine for any minimal mods...
i think there's a thread a little ways down about someone trying to install their SAFC.....and if i remember correctly there's a wiring diagram in it also
congrats BTW
jab11185
zerothread?id=121052
that's the thread...i belive the diagram is correct also...it's all common sense after that
Structure240sx
apex-i's usa site has all the manuals and diagrams you need
Craving4Boost
Car: 91 240sx fastback
it's not hard just use solder the wires together for a good connection. i tried to get out of doing that by using these junk connecters and it turned out a mess
fabio420
Car: 1995 nissan 240sx se
Definetly use a soder. I'll also vouch for that. However, as for the diagram I foung there was another listed on the book that more accurately represents the wires (at least for my 95 s14) I believe it was 5n-b or something. the only wire that doesn't correspond is the throttle, which is the fourth one on top, on the first cluster of 4 holes (It helped that I also had the factory manual that tells me which wire is which. I can prbably post a copy of it if you need. It made my life much easier.
Florida240sx
Know where I can get a soldering gun?Sears looks like they got one for $60...Anyone know about the coldheat wireless one?Looks like I can have one here by Tuesday....It's only 20+shipping
fabio420
My friend just got a coldheat. Here's the truth: I used it for my SAFC and it holds. However, it is a pai in the @#$ to use because it doesn't get hot enough. The job of 6 wires took me 45 min to do it. If you can, go sodering iron. The sears one sounds OK.
Florida240sx
Might just crimp them.I do very professional installs.Never had a problem with anything in my car or my friends.
fabio420
I usually don't hav this problem with other wires, as most are not sodered in fact. However, the SAFC can be a little extra touchy. At first my throtle sensor was messed up, so I sodered everything.
Jookmasta
to tell u the truth, i really did mine with electrical tape. it was fairly neat and i take about five to seven minutes with one wire and electrical tape. i did the twisting method if u will and its been holding up. no issues over here. i suggest the crimping tho with other connectors besides the ones it comes with. soldering could get messy if ur a rookie at it so just get some practice in b/f ya do it on the super short ecu wires....
Florida240sx
I'll just use my installation skills and splice without soldering.Might grab a gun and try the first one though...
