Scandinavian Flick »
https://forums.nicoclub.com/scandinavian-flick-u100311.html
Sun Aug 03, 2008 7:36 pm
well since now one else has yet, ill throw ya some answers/ideas
if all it is, is that the tire pressure monitor light is on, then just add some air to the tire, as for the mixing of air and nitrogen.. just add the air, its 70% nitrogen anyways, the whole idea behind nitrogen inflation is that nitrogen molecules are larger then the molecules that make up airand therefore leak out slower, well 10 years now of filling up tires with regular air and ive never had a problem.
odds are one of your tires is just low, so add the air and that should turn off your light within a couple of minutes after putting air into it, i mean unless your tire is going flat everyday you probabally wont have to replace a tire, and say you did drive over a nail or something, you could always have it patched/plugged as long as its not in the sidewall.
also what does the first service involve? without ever having of done it, i bet its a scam/ripoff,
