NissanAltimaGuy wrote:I changed my oil for the first time on the Altima today. I'd like to extend the middle finger to the engineer who put the filter right above the frame. Makes for a messy oil change.
I guess there's no way around it when the engine's mounted sideways. But still.
I haven't changed my oil yet or seen where the filter is, but it sounds like my Honda Odyssey van. The filter on that is right above the cross member and could make for a real messy oil change. I took a milk jug and trimmed it to fit above the frame and allow the oil to drain directly into the oil pan. Problem solved.
Lots of vehicles do not appear to be designed with clean oil changes in mind... the worst I've had was an RX-8. Filter is on the firewall and pretty much vertical. I used to punch holes on the top of it and let it drain... even still I would get some oil down the side of motor and transmission. My motorcycle has a filter sticking off of the front of the motor with the header pipes below it, that's an easy fix after cramming a funnel between two of the pipes. There are ways to get things done.
While I'm at it... what is the oil filter p/n for this car? I use PureOne filters and will probably pick up a few to put on the shelf.
