180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue May 11, 2004 2:27 pm
Seva-s13 is giving very solid advice. do the tune up thing and make sure it's running well before you plunge into the aftermarket stuff. I spent quite a bit on the parts for maintainence and repairing stuff that needed replacing. First couple parts that went out on me were alternator, water pump, and the radiator. Look for old and leaking hoses and replace those, might also want to consider a brake upgrade before adding power since the 240 is known for a weak stock system.
