First mod in the books!
vasekvi
Car: 2008 Infiniti M45 S
It's all the little things that make a difference..
I don't understand why Nissan decided it would be a good idea to not allow the CF door to not be in place while you have a card in the slot. What if you spill a drink or something in there?
Anyway problem solved. Anyone else end up doing this?
Fail. Smh.
Found the culprit, piece of plastic in the way that has to go
Just cut this little bit of material off and that's all you need. Image
Ahh.
And all is good with the world
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
I don't know why I didn't think of that :facepalm:. This has always bothered me, but never even thought to really look at it. Ill be doing it in the next two hours. Thank you.
This is like watching Shark Tank and saying, "it's such a simple and common sense idea, why didn't I think of it?"
vasekvi
Just doing my part as the forum noob :-)
Wangtang408
Car: 2006 Infiniti M35
WOW that's awesome, can this be done on 06/07 models?
vasekvi
Wangtang408 wrote:WOW that's awesome, can this be done on 06/07 models?
Looks like the same door to me so that should be a yes.
Wangtang408
So you just need to make a cut out and there is a slot inside to connect the CF card to?
vasekvi
Wangtang408 wrote:So you just need to make a cut out and there is a slot inside to connect the CF card to?
No. After you cut the plastic off you just insert the card normally and put the plug over the card.
TXT
Car: 2006 M45 Sport
You cant do this in the 06 model and I believe the 07 model as well because the CF card slot didn't exist for those years.
vasekvi
TXT wrote:You cant do this in the 06 model and I believe the 07 model as well because the CF card slot didn't exist for those years.
By golly you're right. Well obviously this won't work unless the car is equipped with the CF slot
Looked at pix of 07 models also and saw no slot.
Wangtang408
Thanks for confirming TXT. What a bummer!
