WDRacing wrote:I was running 20 psi on a SAFCII and MSD BTM setup with the same turbo you chose except I was using 42lb injectors at 60psi of static fuel pressure and a touch of alcohol on high boost.
Daily driven she was set at 1 bar (14.7) psi. I set my BTM to .5 lbs of retard per psi and it worked great.
Many people on here will dis the SAFC, I think they just had a hard time or operator error leading to a problem or three and decided it's easier to blame a box rather then take responsibility.
Those are the guys that swear by the ROM tunes...personally I like the ability to change the tune if I want to.
I'm working on a complete standalone fuel system at the moment. Basically it's setup to run off of a MAP sensor and only add fuel in direct proportion to boost. This will let everyone keep their stock ecu and MAF and totally eliminate the idle problems everyone has.
But don't ask when it will be out, most likely not till next summer.
WD
lol its funny you think I botched an afc install/tune , main issue is it advances timing with the fuel you add for boost nope.
now as for me being bias towards safc I'm not, but when you can have a fully working tune that needs no fuel correction, because its tuned to the needs you have and SHOULD have some overhead for future upgrades, why use safc A LOT OF people cant do rom tunes, I can. If I couldnt I'd be on afc and btm myself, not twittling my stick you know.. now the btm is why I say bandaid, without it you would blow a motor thanks to the afc addign timing. Ask my boy hawk about it. " I had some lean spots so I added fuel with an afc, 55 miles later I blew the motor" we both got up about the same time, I am still runnign strong he will be back up and running in the morning IIRC
cost comes down to purchase most of the time, I was broke when I neded a tune, afc was out(going for 150+ at the time on the bay)
as for being able to change my tune no problems here 5 minutes max including removal/install/changes. emulator and some datalog or consult and your doing realtime tuning for less than a NEW neo safc.
I daily drive my car too man at 7~9psi depending on my mood, drift that ***** all the time, with stock 270cc injectors and sohc maf. I geuss it really doesnt matter its all personal choice in the end, damn sure dont pick one because its what someone else had luck with choose what suites you.
Just get it done by whatever means you choose. damn I didnt want to waste that 5 minutes.
