OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Fri Apr 26, 2013 11:43 am
Welcome to NICO! When I bought my Q almost 3 years ago, I thought it could run better with new plugs. So when installing new plugs I found the plug wells for cylinders 1 and 2 contained a large amount of oil from a leaking valve cover gasket (note 90-93 use RTV) instead of a gasket. I replaced the plugs and noticed an improvement but it still lacked the power I thought it should deliver. About two weeks later I developed a miss that turned out to be two failed injectors. An item to note about the VH45DE is it will seem to run ok on 7 cylinders with a failed injector. When the 2nd injector fails then you will really notice a miss.
Over the past year my 16 yo son has been with me when we looked at a couple of used Qs for sale. He will put his hand on the plenum and give the engine a slight revup where he pointed out something is wrong like the engine is running on 7 cylinders or less.
After two injectors tested bad, I decided to replaced all injectors, all under plenum hoses, heater pipe, knock sensors, and the knock sensor wiring harness. If you get ready to tackle pulling the plenum we can show you some pictures and there are many threads on here about pulling the plenum.
