Stupid me thought the heat shield was the east part AFTER going to Harbor Freight earlier that day to buy an axle grinder, grinding disc, and cutting disc to remove the LAST bolt on the top right!
I didn’t know what the hell I was doing but half way through I remembered this guy on Reddit.
So I put on my safety goggles, n95 mask, and bicycle helmet on sans gloves. I already delt with the Rogue Springs and compressors but this is more dangerous to me.
But after removing that bolt, I ended up with a mind/bending heat shield metal puzzle where you can’t remove it.
I almost wanted to use my axle grinder but I already took a chance on fate and decided to torture myself trying to remove the damn thing.
On my 2009, if you don’t spend hours, you might find the nano-atom size clearance to bust this thing out while breaking a few brackets. I did disconnect the oxygen sensor but I didn’t know how to remove bracket until I broke it. And I didn’t know how to disconnect the o2 sensor until I found a non-English speaking guy on YouTube show me how too.
Oh yeah that same 1 last bolt stopped me from ever changing my thermostat previously until I got a dreaded code recently.
I’m actually thinking about using the axle grinder to safely cut the oem heat cover and maybe use it in front of the heat armor I ordered on Amazon for $98 and right after I got that last one, the next batch showed up for $129 so I was lucky there.
