First gen won't stay running?
2010rogue
Car: 2010 AWD Rogue SL
I have a 2010 and it starts normal for exactly one second then shuts off. I cant find anyone experiencing the same issue. Its very robotic shut off... Everytime like the comp is shutting off fuel. So far ive ruled out the cam/ crank sensors, fuel pump, idpm, battery.. Etc. Everything works normal but the car will not stay running. It responds to throttle increase in the 1 second, but still shuts down immediately. 0 codes... Im stuck. Wondering if its security related? Even though the keyless start works fine and ive tried the key in the ignition. Nothing changes the behavior.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Additional things to check:
Mass Airflow Sensor
Fuel Pump Relay
Ignition Coil
Fuel Injection Sensor
Body Control Module (BCM)
2010rogue
I was told if it was MAF related that unplugging the sensor would allow it to run off computer presets? If so the MAF doesnt seem to be the culprit. The fuel pump relay was replaced when I did the idpm. Im not sure how to test the bcm, but a fuel injection sensor does sound like a great thing to check.
I believe the coil is good, but will check it. Thanks for giving me some more leads, i was getting pretty discouraged.
Rogue One
2022 Honda Pilot SE
Cool beans. Just for giggles you can pick up a replacement MAF from Amazon for less than $30 (although I suspect that's not the problem). If it's the BCM, taking your car to the dealership or your preferred certified mechanic is going to be your best option.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
A similar thing like this happen to my 2009 last year.
But I eventually got another lean bank code again.
Because of the crappy ethanol gas I am forced to use for the last decade.
I was hoping it was because of the dirty buildup in my fuel injectors or fuel system.
So I did a cheap solution or hoped it was,
Bought some BG44k & Techron. Supposedly these have the best ingredients in cleaners.
My rogue been starting and running smooth ever since.
I’m not really into engine additives because I never really believed in them,
But wtf, my rogue was nearly a decade, so I had nothing to lose.
Also didnt want to take to dealership if I can avoid it.
I already put the crappy ethanol gas in my rogue so let me just give a these go to fuel cleaners a try.
It even fixed my fuel gauge and shows all orange bars after being broken 9 years.
So it did help my fuel system.
Also cleaned my maf sensor again just in case too.
I also broke my habit of trying to fill the tank after it stops.
Heard that might mess up the fuel system.
So give the cleaners a try, better alternative than the dealership.
My rogue runs smooth as hell, only thing I have in the back of my mind is that the cvt will crap out.
I still have the original cvt.
I babied it 99% of the time.
Only time I went crazy was when I used sea foam and did an Italian tune up and floored it like a drag racer.
Completely stomped it to the floor a half dozen times.
This happen many years back.
Really stupid but it still running smooth as butter.
Return to “Rogue Forum”
