MoldyOldy240 wrote:I haven’t looked but does the FSM have all the torque specs I would need to assemble?Are there any note worthy steps that I must know (like order of tightening, etc.)?Does anyone have a website/book/dvd/forum post that they think I should read?
Thanks gang!
Yes, the FSM has all the torque specs.
FSM tells you the loosening and tightening order of everything, but most notably the head bolts and cradle bolts are the ones that you need to pay attention to.
Uhhh there was a website i saw a few months ago with just pics of the rebuild, but it's really straightforward. I think the most complicated part of the engine is the intake manifold lol. What I did was take off the intake manifold and rebuilt that first, before even taking the valve cover off. That way you can remember where all the vacuum and coolant hoses go. After you put that back together then set it aside and start taking apart the engine. What I did was with all the brackets and stuff that go on the sides of the block, I just took off the brackets and put the bolts back where they go. The valve cover comes off with all those bolts on top, then loosen the cams. Next take off the upper an d lower front covers, before you take off the lower cover take off the crankshaft pulley. Take the cams off all the way and take off the chains, then you have access to the head bolts. They are allen bolts btw. Take the head off and you can see the pistons. Take the oil pan off, flip the engine over, remove the oil strainer, and remove the crank cradle. Then you can loosen the rod bolts. Once those were off I got an extension and put it into the bottom of the pistons and tapped them downwards so they came out the top of the engine (engine was upside down remember). I didn't care about the bottom of my pistons or the cylinder wall because I have new oversized pistons. After that, you can take off the rear main oil seal plate thing and then tap the crank upwards with a rubber mallet so it comes out. Bam...you have the block just chillin there. With the bolts all in the side of the block I got some styrofoam and put the bolts into the styrofoam in the same pattern as they came out of the block so I know where each bolt goes. 2 pieces of styrofoam, one for each side of the block.
With the head, turn it upside down so the cam buckets/shims/whatever they are fall out, and MAKE SURE YOU KEEP THEM IN ORDER, THEY NEED TO GO BACK IN IN THE SAME SPOTS!!! Then get a valve compressor tool and you can take the valves out and replace the valve seals. Take the whole shebang to the machine shop, wait for them to call you back, go pick it up and put it all back together.
Congrats, you have a brand new KA ready to be boosted...or in your case, a reliable daily driver haha. Good luck.
-Chris
