Spectre23 »
https://forums.nicoclub.com/spectre23-u11197.html
Mon Feb 28, 2005 12:51 pm
Well, I have a boost leak so I am only getting up to 14.5 psi and running 10:1 A/F, so of course these numbers will improve. The drive tires I have (for reference) are 245/45-16's. I made 245 lb/ft and 232 HP. The funny part is, I made identical numbers as my friend that has a SR with exhaust and Mine's ECU, but my power came in 1100 RPM later and stayed 1000 RPM longer.
My power mods are: GT28R, 440cc, 50 psi fuel pressure, Nismo FPR, Walbro 255, turbo back 3" w/o cat, ARC SMIC
Not great numbers, but not bad for as poorly as the car is running with that huge boost leak. I will keep you updated once I get better numbers.
