iNfamous240 wrote:... It all depends on how you fix it up and how much money you spend on it. IMO, a ka is a better angine for boost. You guys might disagree but THATS MY opinion. And from what i heard there are a lot more sr engines blowing up do to boost then ka-t's so maybe you should get your facts straight before you go off and post something thats not true.
If I might ask, where do you get your facts from?
Do you base the fact that the KA block is cast iron, while the SR block is aluminum. And by being cast iron, that some how better suits the block to stand boost? I'm curious, because I've heard that argument used many a time.
If that's what you're basing your KA-T bias on, then please allow me to retort.
Have you disassembled both a KA and an SR? Have you truly taken the time to look at the intricies of the blocks?
If you have, maybe you've noticed all of the webbing built into the SR block around the cylinders, that isn't there on the KA.
I'm not even going to go into the head, other than to say the SR revs to 8000+ with ease, while most KA guys aren't looking to spin more than 7000 out of their motors.
Anyone who knows anything about a built motor will tell you that the KA can take boost. Nathan is running 21psi. There are numerous people making ~400hp. Even more in the 300s. I think that you'll find, by and far, they're nearly all drag racers. They might have some freak accident where a hose flies off, and the boost skyrockets through the roof, overspinning the turbo and grenading the motor... it's not likely though.
A turbo motor is going to blow up on a race track, at sustained high RPMs. I doubt that you'll find anyone willing to subject a KA powerplant to a road race environment. The motor simply isn't engineered to SUSTAIN boost. It can handle it, in huge chunks though.
I'll take an SR powerplant over the KA for the above stated reason. I want to road race one day. Sure, it's cool to be able to eat Porsche's and the like off of the line. It's a whole different world entirely to hang alongside them for an hour or two.
I've seen wrecked SR's. They are all due to bad tuning. There are too many guys who get their hands on one, slap on a boost controller, FMIC, intake and exhaust, then fry their pistons because the stock fuel system can't cool them down quickly enough. The SR is a significantly more popular setup, therefore more people do it, therefore fewer people do thorough research like KA owners do, and because of that, people like you are able to come onto a board like this, and say "SR's blow up all over the place." No sh it?
For a factory stock bottom end, it's really hard to come close to the SR20DET (2JZ comes to mind though). You'll find that people who "build" their KA-T bottom ends, are only running about 350-400hp. That's about what a well maintained, STOCK, SR20DET bottom end will hold.
If you're willing to consider that SR20DET bottom ends can be built, then you'd realize for about $8000 you can have a 2.2L stroker motor that will happily handle 600-700hp at 8000+ RPM with the appropriate headwork.
Just to add some flames to the fire
In the bench racing world, or even the real world if I ever get my hands on such a motor... I'll put a built 2.2L SR20DET against any 2.4L KA-T down the 1320. I bet the higher revs will overcome the 0.2L displacement disadvantage.
