gah171 »
https://forums.nicoclub.com/gah171-u153985.html
Sun Mar 14, 2010 10:42 am
I read the link you sent me, page 35 says turn ign on, turn test mode dial on ECM clockwise, the red and green starts flashing. once, twice, three, four, five and repeats itself, after 2 minutes turn dial counter clockwise. then you get a code. in my case red and green lights stayed on steady. I did not get a code. link says (page 36)" if the LED does not blink check heated oxygen sensor . I did this test again and I finally did get a code- after turning dial counter clockwise, red flashed 4 times, green once. I got a code 41.I watched the sequence several times. there is no code 41 on list. I tried it again to see if I could get the same code or different code. red and green stayed on steady like before, couldn't get another code. Think my ECM is bad ? will the one in my 95 the same ?
