Eyedea wrote:9/13/2008
Got some wheels 5Zigen Gravis-I (2) 19x9.5 ( +25mm offset front) & (2) 20x9.5 ( +20mm offset rear) in polished finish. Will test fit and see if i like them. Test fit pics tommorow 9/14
Cakedaddy: this is what is called flush. ROFLMoney Shot #1From front
This is the Side Shot.Overall it came out nice, Yes, Rear need to be slammed a little, Will be Cutting a coil when I roll my fenders.Apologies for the dirty car. Will try and get some cleaner shots later after I give the car a wash
Flush?? There is that word again. Be careful, the rims seems to be exposed, but that may be due to the tire width being to small or the rim being too wide. 5 Zigen.... Those are tuner wheels, correct? I thought you'd go for more of a "VIP" style wheel to compliment the VIP body work instead of the honda tuner style. Please do not cut your coil! You will regret that!!! You'll ruin your launch from stop signs and red lights. The car will also squat in the rear once you attempt to punch it, plus it will bounce at high speeds when you hit the slightest dip. Remember, we do have RWD cars with 330+ lbs torque that weights nearly 4000lbs I've seen springs cut on FWD acura's/honda's with decent results, but the keyword is DECENT. Props to you on getting the kit put on.
____________________• Locomotion:Y34 ~ 4.5Liter V8 ~340HP~ 333lbs Torque• Construction: Blk'd Out Grill, Blk'd Out Side Marks • Coloration: Black Obsidian• Elevation:Eibachs • Rotation: f 20x8.5 245/35zr ~~ r 20x9.5 265/30zr• Rotation Specs: f 34mm offset ~~ r 40mm offset• Rotation Design: Foose Speedsters on G-Force T/A KDW 2 • Reflection: 5% Tint All Around• Vision: OEM 4300K HIDs w/ H3 Piaa Yellow Fogs •
http://www.cardomain.com/ride/2690246
Modified by CakeDaddy at 7:02 AM 9/22/2008
