Jehtte »
https://forums.nicoclub.com/jehtte-u180866.html
Fri Mar 25, 2011 10:15 am
I use a Greddy Profec B spec 2 controller, will easily work up to 450. I know nothing about front mounts... maybe someone else will chime in. ECU stuff can get expensive, and my knowledge is somewhat limited there as well. If you have the money I reccomend a final setup with 720 nismo injectors and a pair of JWT 530 bb turbos, which in and of itself should cover you up to 500+ with minimal lag. You will need an EPROM upgrade to run that setup which is again beyond my understanding.
Also, The controller will act as a boost gauge if you don't mind reading in kpa.
