first 240 nd needing a little help
scottidoo
Car: 95 240sx
So this is my first 240. Nd whenever I gun it the intercooler pipe pops out of the rubber sleeve.I've already replaced the clamp nd still happens.I'm planning in getting a new sleeve nd seein if that works.....anyone have any adive
TTkickedin
Car: 1991 Nissan 300zx TT 5 speed, t-tops, < currently in intensive care unit!
2011 MBTA BUS
Get better Intercooler Hoses. Samco makes great hoses. Image
Replace your clamps with these http://www.turbohoses.com/Clamp.htm
Make sure there's no oil or anything slippery on your intercooler pipes. And make sure the ends of the pipes are dimpled, if they're not, they're more prone to slipping hoses off under hard boost. Get a better intercooler pipe kit (you can search for that.)
scottidoo
Car: 95 240sx
Kk thank you.also. It doesn't lil starting in the cold nd has low rpm nd will die out sumtimes when I go to stop but I heard for that I just need to ospray sun carb cleaner in the iaa valve while its running nd keep it above 1000 rpm. Is that right
TTkickedin
2011 MBTA BUS
IAC valve? You might want to use Intake cleaner instead, as carb cleaner is a harsher chemical and could mess with your MAF sensor (Carb cleaner also melts plastic...anything involving something plastic or electrical like a chip/motherboard, you don't want to use carb cleaner around.)
and use this thread, but instead use Intake cleaner as I stated.
how-to-clean-a-redtop-iacv-valve-with-c ... 51731.html
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
A far as the intercooler pipe popping out, it used to happen to me all the time. Weld a lip on the end of the piping and problem solved.
