elvis240sx »
https://forums.nicoclub.com/elvis240sx-u1160.html
Mon Jun 23, 2003 4:16 pm
OK, i've been searching around but i am still unclear as to the exact specs of the firing order. I know that the firing order itself is 1 3 4 2. and that the cylinder closest to front of engine is #4, while cylinder closest to firewall is #1.
now, how to i hook these up to the distributer cap? which plug on the cap goes to cylinder 1? which to 2? and so on. how do i tell where to plug them in to make it fire in a 1 3 4 2 order? by the way, all of this info that i found was for dohc engine, this is the same for a sohc engine right? my engine is sohc, i just want to check to make sure the firing order it ok, i changed the plugs a while back and maybe i screwed up the wires. if anyone can help, i would appreciate it
