Firewall
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
doci
Car: 2009 Nissan Versa 1.6 Base
Can someone snap a picture of the hole in the firewall, both inside and under hood, so I can see where I need to run my power cable. There is a thread with a pic but does not display any longer. Get the red X. Thanks in advance.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
You have to remove the intake and battery to get to it from the outside. Or at least to SEE it. There's a trick where you can take a metal hanger, tape the wire to it, and poke it through the grommet and feed it out to the top of the engine bay. I've done it several times.
NODES
Car: 2007 Nissan Versa SL (Blue)
I did it by making a slit in the rubber boot and attaching a wire to a coat hanger and pushing through.
I did not have to remove anything to do it...
Return to “Versa Technical Discussions”
